锥面活塞环锥度方向的快速识别方法
消耗积分:2 | 格式:rar | 大小:106 | 2009-06-22
分享资料个
为提高普通锥面活塞环锥度方向的检测效率,提出一种可快速判别多片同直径锥面活塞环锥度方向的方法,并介绍了测量过程中传感器最佳采样步距的选取方法和活塞环之间间隙的判别原则。
关键词:锥面活塞环,  锥度方向,  采样步距,  间隙判别
Abstract : A fast recognition method for the taper directions of multiple taper2face piston rings with the same diameter is pre2 sented to improve the recognition efficiency. The choice method for the best sampling pace of the sensor and the recognition princi2 ple of the gap between the piston rings during the recognition procession are introduced.
Keywords : taper2face piston ring ,  taper direction ,  sampling pace ,  recognition of gap
评论(0)
发评论
下载排行榜
