利用线阵CCD非接触测量材料变形量的方法
消耗积分:3 | 格式:rar | 大小:128 | 2009-06-24
分享资料个
用线阵CCD 作为光电传感器非接触测量材料拉伸过程中的变形量,不但比常规的引伸计
测量的方法更客观,而且可以测量材料拉伸变形到断裂的全过程。该方法能在X 和Y 两个方向上同时测量材料变形量,可以获得材料在实验的全过程中两个方向的"应力-应变"关系曲线。采用CCD 拼接技术,测量精度可达到1mm,测量范围80mm。
关键词:非接触测量;线阵CCD;应力测量;变形测量
Abstract: Measurement of the deformation quantity of a material during stretching process by using linear CCD detectors in non-contact mode, not only is more objective than the common extensometer measurement method, but also can measure the whole process from stretching deformation to breaking .The deformation quantity of a material can be simultaneously measured at both direction of X and Y and the stress-strain curves of the both direction during the whole experimental process of a material can be obtained. With CCD splicing technique, the measuring accuracy can be reached 1mm and measuring range 80mm.
Key words: Non-contact measurement;Liner CCD;Stress measurement;Deformation measurement
评论(0)
发评论
下载排行榜
