分析粗规格弹簧钢丝收卷时影响排线整齐的因素,通过重新设计收线轮转速和光杆转速之间的速比,提高收线轮加工精度, 并在排线器刻度盘标明不同规格钢丝应指示的位置,达到平整紧密收线的目的。 关键词 弹簧钢丝;收线机;排线 Abstract To analyze the factors affecting wire ranging in orderwhile thick sp ring steelwire being coiled. By redesigning the rotation speed ratio between take2up and bare pole, raisingworking p recision of take2up reel, and marking the positions atwhich different diameter steelwires should indicate, the flat and compact take up goal is reached. Keywords sp ring steelwire; take2up; wire ranging
