提高光电型红外转速传感器测量准确度的方法
消耗积分:5 | 格式:rar | 大小:169 | 2009-06-30
王璐
分享资料个
在应用中容易受阳光和照明光线等杂散光线的干扰。采用跟踪动态电平的平均值电路、适当的光学及机械结构、单片机解决这一问题,使光电型红外传感器在非接触转速测量中的抗扰能力和测量准确度都会有明显提高。在调速系统和机械振动位移系统中将有着广泛的应用。
关键词: 光电型红外传感器; 转速; 测量准确度
Abstract : Photoelectric infrared sensors are objects to the interference of sunlight and illumination light . Adop2ting average circuit ,optical and mechanical structure and the singe chip processor ,the problem is resolved ,Theca2 pability of anti2interference and measurement accuracy are improved obviously in non2contact rotation speed mea2 surement. The methods will have comprehensive use in speed governor and mechanical vibration displacement system.
Key words : photoelectric infrared sensor ; rotation speed ; measurement accuracy
评论(0)
发评论
下载排行榜
