有关ov7670的程序
Your Licence to Use the Source Code and Specification for the Cortex Microcontroller Software Interface Standard:
THIS END USER LICENCE AGREEMENT IS A LEGAL AGREEMENT (“LICENCE”) BETWEEN YOU (EITHER A SINGLE INDIVIDUAL, OR SINGLE LEGAL ENTITY) AND ARM LIMITED (“ARM”) FOR THE USE OF THE SOURCE CODE AND SPECIFICATION ACCOMPANYING THIS LICENCE. ARM IS ONLY WILLING TO LICENSE THE SOURCE CODE AND SPECIFICATION TO YOU ON CONDITION THAT YOU ACCEPT ALL OF THE TERMS IN THIS LICENCE. BY CLICKING “I AGREE” OR BY INSTALLING OR OTHERWISE USING OR COPYING EITHER OR BOTH THE SOURCE CODE AND SPECIFICATION YOU INDICATE THAT YOU AGREE TO BE BOUND BY ALL THE TERMS OF THIS LICENCE. IF YOU DO NOT AGREE TO THE TERMS OF THIS LICENCE, ARM IS UNWILLING TO LICENSE THE SOURCE CODE AND SPECIFICATION TO YOU AND YOU MAY NOT INSTALL, USE OR COPY THE SOURCE CODE OR SPECIFICATION, BUT YOU SHOULD PROMPTLY RETURN THE SOURCE CODE AND SPECIFICATION TO ARM.
“Source Code” means the source code for the Cortex Microcontroller Software Interface Standard.
“Specification” means the specification for the Cortex Microcontroller Software Interface Standard. Notwithstanding the foregoing, “Specification” shall not include (i) the implementation of other published specifications referenced in the Specification; (ii) any enabling technologies that may be necessary to make or use any product or portion thereof that complies with the Specification, but are not themselves expressly set forth in this Specification (e.g. compiler front ends, code generators, back ends, libraries or other compiler, assembler or linker technologies; validation or debug software or hardware; applications, operating system or driver software; RISC architecture; processor microarchitecture); (iii) maskworks and physical layouts of integrated circuit designs; or (iv) RTL or other high level representations of integrated circuit designs.
