全英版XPT2046触摸控制IC规格书
消耗积分:0 | 格式:pdf | 大小:885KB | 2014-08-19
pwater
分享资料个
The XPT2046 is a 4-wire resistive touch screen controller that incorporates a 12-bit 125 kHz sampling SAR type A/D converter。The XPT2046 operates down to 2.2V supply voltage and supports digital I/O interface voltage from 1.5V to VCC
in order to connect low voltage uP。
评论(0)
发评论
下载排行榜
