UC3854开关电源设计软件 2.0M
消耗积分:1 | 格式:rar | 大小:427KB | 2014-10-11
夏敏
分享资料个
The UC1854 provides active power factor correction for power sys-tems that otherwise would draw non-sinusoidal current from sinusoi-dal power lines。 This device implements all the control functions necessary to build a power supply capable of optimally using available power-line current while minimizing line-current distortion。To do this,the UC1854 contains a voltage amplifier, an analog multiplier/divider,a current amplifier,and a fixed-frequency PWM。In addition, the UC1854 contains a power MOSFET compatible gate driver, 7.5V ref-erence, line anticipator,load-enable comparator, low-supply detector,and over-current comparator。
下载资料需要登录,并消耗一定积分。
评论(3)
发评论
youxi10 2015-10-24
0 回复 举报
学习一下 收起回复
balismy 2015-08-08
0 回复 举报
下载下来了 东西很好,功能也很强大 支持原创!! 收起回复
全部评论
下载排行榜
全部3条评论
