AT89C52全英版资料
消耗积分:1 | 格式:pdf | 大小:197KB | 2014-10-15
h1654155805.2360
分享资料个
The AT89C52 is a low-power, high-performance CMOS 8-bit microcomputer with 8K bytes of Flash programmable and erasable read only memory (PEROM)。The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard 80C51 and 80C52 instruction set and pinout。 The on-chip Flash allows the program memory to be reprogrammed in-system or by a conventional nonvolatile memory programmer。 By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C52 is a powerful microcomputer which provides a highly-flexible and cost-effective solution to many embedded control applications。
评论(0)
发评论
下载排行榜
