本文以两片定点DSP TMS320C6203 为核心,设计了一个用于处理1024×1024 大小图像(12 位数字相机)的电视跟踪系统,并对系统的硬件设计和软件设计分别进行了详细介绍。对实时图像序列进行预处理后,DSP1 进行捕获和图像增强、显示,DSP2 用于实时 跟踪。主要解决了两个关键问题:第一, 采用分段投影的方法,解决了对于大图像大数据量的目标全屏捕获问题,并满足实时要求;第二,根据目标大小动态调节跟踪窗,对目标进行实时跟踪。实验表明系统对目标的实时跟踪有很好的性能。 关键字:双DSP 平台,实时跟踪系统设计,12 位数字相机 Abstract: In order to meet the requirement of the real-time video tracking System, we can utilize the embedded double DSPs to assign multi-task efficiently and reduce the processing time. This paper also resolved two key problem: first, in order to capture the target in the huge video image(1024*1024), we use the projection method group by group; second, the tracking window can be adjusted according to the size of the object. The examination proved the tracking system works well and all the purpose can be reached. Keywords: DSP TMS320C6x, real-time tracking system, 12-bit camera
