The OP07 has very low input offset voltage (75 μV maximum for OP07E) that is obtained by trimming at the wafer stage。 These low offset voltages generally eliminate any need for external nulling。 The OP07 also features low input bias current (±4 nA for the OP07E) and high open-loop gain (200 V/mV for the OP07E)。The low offset and high open-loop gain make the OP07 particularly useful for high gain instrumentation applications。
