ACS780xLS Datasheet
消耗积分:0 | 格式:pdf | 大小:411KB | 2015-04-09
abcwaq230
分享资料个
The Allegro ACS780 is a fully integrated current sensor linear IC in a new core-less package designed to sense AC and DC currents up to 150 A. This automotive grade, low profile(1.5 mm thick) sensor IC package has a very small 5 mm ×
5.6 mm footprint. The Hall sensor technology also incorporates common mode field rejection to optimize performance in the presence of interfering magnetic fields generated by nearby current carrying conductors.
评论(0)
发评论
下载排行榜
