半实物仿真系统中数据传输与采集系统设计
消耗积分:3 | 格式:rar | 大小:191 | 2009-08-04
哈哈哈
分享资料个
提出了一种红外敏感器半实物仿真系统中多路实时数据传输与采集系统的设计方法,采用FPGA 内的SRAM 块实现所要传输与采集数据的缓冲存储,并通过高速USB2.0 接口芯片实现与主机的接口,最后,由主机工作站完成对数据的后期处理。该硬件系统作为整个仿真系统的一部分,具有数据传输高速、准确、实时等特点,满足实时仿真系统的要求。
关键词: 数据的传输与采集;USB2.0;FPGA
Abstract: A real-time, multi-channel data transmission and acquisition system of Hardware-in-the-loop Simulation system of infrared sensor is presented. The transmitted and collected data is buffered and memorized in SRAM block in FPGA, and USB2.0 interface chip, whose transport speed is high , was used as the interface between system and the PC, at last, data would be treated in PC. The system of hardware has the characteristics of high speed, high precision and real-time, and meet necessaries of simulation system.
Key words: Transmission and Acquisition of Data; USB2.0; FPGA
评论(0)
发评论
下载排行榜
