基于AES的远程访问的认证协议
消耗积分:3 | 格式:rar | 大小:165 | 2009-08-05
刘埃生
分享资料个
本文提出了一种基于AES 实现的口令认证方法。该算法不使用公开密钥算法,仅采用AES 进行远程用户的身份认证。该方法具有速度快,安全性高的特点,易于采用令牌(Token)或IC 卡硬件实现。在本文的最后,还对认证协议的安全性进行了讨论。
关 键 词: AES;哈希函数;认证协议
Abstract: An AES-based password authentication mechanism is proposed. The algorithm overcomes the conventional synchronization problem based on counter mode. Based on AES----a absolutely secure algorithm under present technology, this mechanism can be implemented with the properties of fast speed and high security, and it is easier to be implemented by Token or IC card hardware. Besides, one authentication protocol
is proposed, which is aimed at satisfying security and created by final authorization passcode and digital signature that is built by userID and local token. In the end, the security problems of the protocol at two aspects----algorithm security and protocol security are discussed, and AES-based password protocol is with high security is the result.
Key words: AES;Hash technology;Validation protocol
评论(0)
发评论
下载排行榜
