门电路74AC163资料
消耗积分:2 | 格式:pdf | 大小:112KB | 2015-12-24
李大哥
分享资料个
The AC/ACT163 are high-speed synchronous modulo-16 binary counters. They are synchronously presettable for application in programmable dividers and have two types of Count Enable inputs plus a Terminal Count output for versatility in forming synchronous multistage counters. The AC/ACT163 has a Synchronous Reset input that overrides counting and parallel loading and allows the outputs to be simultaneously reset on the rising edge of the clock.
评论(0)
发评论
下载排行榜
