直接虚拟内存访问异构FPGA的高生产率_英文版
消耗积分:0 | 格式:pdf | 大小:347KB | 2015-12-31
如果没有
分享资料个
Heterogeneous computing utilizing both CPU and FPGA requires access to data in the main memory from both devices. While a typical system relies on software executing on the CPU to orchestrate all data movements between the FPGA and the main memory, our demo presents a complementary FPGA-centric approach that allows gateware to directly access the virtual memory space as part of the executing process without involving the CPU. A caching address translation buffer was implemented alongside the user FPGA gateware to provide runtime mapping between virtual and physical memory addresses.
评论(0)
发评论
下载排行榜
