Max232 串口电平转换芯片
消耗积分:10 | 格式:rar | 大小:3041 | 2009-08-06
建立建利12
分享资料个
Max232 串口电平转换芯片:The MAX232 device is a dual driver/receiver that includes a capacitive voltage generator to supply EIA-232 voltage levels from a single 5-V supply. Each receiver converts EIA-232 inputs to 5-V TTL/CMOS levels. These receivers have a typical threshold of 1.3 V and a typical hysteresis of 0.5 V, and can accept ±30-V inputs. Each driver converts TTL/CMOS input levels into EIA-232 levels. The driver.
评论(3)
发评论
Agelessxie 2016-12-04
0 回复 举报
谢谢楼主 收起回复
结账下机 2012-09-07
0 回复 举报
挺好的资料 收起回复
全部评论
下载排行榜
全部3条评论
