TOP209/210_datasheet
消耗积分:1 | 格式:pdf | 大小:447KB | 2016-01-30
韧涵
分享资料个
The TOP209/210 implements all functions necessary for an off-line switched mode control system: high voltage N-channel power MOSFET with controlled turn-on gate driver, voltage mode PWM controller with integrated oscillator, high voltage start-up bias circuit, bandgap derived reference, bias shunt regulator/error amplifier for loop compensation and fault protection circuitry.
评论(0)
发评论
下载排行榜
