The '197 ripple counter contains divide-by-two and divideby-
eight sections which can be combined to form a modulo-
16 binary counter. State changes are initiated by the falling
edge of the clock. The '197 has a Master Reset (MR) input
which overrides all other inputs and asynchronously forces
all outputs LOW. A Parallel Load input (PL) overrides
clocked operations and asynchronously loads the data on
the Parallel Data inputs (Pn) into the flip-flops. This preset
feature makes the circuit usable as a programmable counter.
The circuit can also be used as a 4-bit latch, loading
data from the Parallel Data inputs when PL is LOW and
storing the data when PL is HIGH.
