针对高速列车列车制动系统存在的复杂性、非线性、时变性、不确定性等因素,本文 设计了用于高速列车制动系统的模糊控制器以实现列车的安全平稳制动。仿真结果表明该控制器提高了系统的反应速度,增加了系统的稳定性、鲁棒性和适应性。 关键词:模糊控制;高速列车;列车制动;控制器 Abstract: The braking system of high-speed train is complex, nonlinear, time-varying, and uncertainties, so in this paper a fuzzy controller is proposed for braking system of high-speed train to achieve a steady and safe braking. The simulating results illustrate that the method can improve the response speed of the system, and increase the system's stability, robustness and adaptability. Keywords: fuzzy control; high-speed train; train braking; controller
