MAX1951/MAX1951A,pdf datasgeet
消耗积分:5 | 格式:rar | 大小:433 | 2009-08-22
分享资料个
The MAX1951A high-efficiency, DC-DC step-down switching regulator delivers up to 2A of output current. The device operates from an input voltage range of 2.6V to 5.5V and provides an adjustable output voltage from 0.8V to VIN, making the MAX1951A ideal for on-board postregulation applications. The MAX1951A total output error is less than ±1.5% over load, line, and temperature.
The MAX1951A operates at a fixed frequency of 1MHz with an efficiency of up to 94%. The high operating frequency minimizes the size of external components. Internal soft-start control circuitry reduces inrush current. Short-circuit and thermal-overload protection improve design reliability.
The MAX1951A can start up safely with a prebiased or without a preexisting output. This feature simplifies tracking supply designs for core and I/O applications and redundant supply designs.
The MAX1951A is available in an 8-pin SO package and operates over the -40°C to +85°C extended temperature range.
评论(0)
发评论
下载排行榜
