PRTR5V0U2X_产品数据
消耗积分:0 | 格式:pdf | 大小:61KB | 2016-08-10
吴建伟
分享资料个
Ultra low capacitance double rail-to-rail ElectroStatic Discharge (ESD) protection diode in a small SOT143B Surface Mounted Device (SMD) plastic package designed to protect two Hi-Speed data lines or high frequency signal lines from the damage caused by ESD and other transients.PRTR5V0U2X incorporates two pairs of ultra low capacitance rail-to-rail diodes as well as an additional ESD protection diode to ensure signal line protection even if no supply voltage is available.
评论(0)
发评论
下载排行榜
