ADA4922-1,pdf datasheet (High
消耗积分:3 | 格式:rar | 大小:418 | 2009-08-26
20615
分享资料个
The ADA4922-1 is a differential driver for 16-bit to 18-bit ADCs that have differential input ranges up to ±20 V. Configured as an easy-to-use, single-ended-to-differential amplifier, the ADA4922-1 requires no external components to drive ADCs. The ADA4922-1 provides essential benefits such as low distortion and high SNR that are required for driving ADCs with resolutions up to 18 bits.
With a wide supply voltage range (5 V to 26 V), high input impedance, and fixed differential gain of 2, the ADA4922-1 is designed to drive ADCs found to in a variety of applications, including industrial instrumentation.
评论(0)
发评论
下载排行榜
