The AD210 is the latest member of a new generation of low
cost, high performance isolation amplifiers. This three-port,
wide bandwidth isolation amplifier is manufactured with surface-
mounted components in an automated assembly process.
The AD210 combines design expertise with state-of-the-art
manufacturing technology to produce an extremely compact
and economical isolator whose performance and abundant user
features far exceed those offered in more expensive devices.
The AD210 provides a complete isolation function with both
signal and power isolation supplied via transformer coupling internal
to the module. The AD210’s functionally complete design,
powered by a single +15 V supply, eliminates the need for
an external DC/DC converter, unlike optically coupled isolation
devices. The true three-port design structure permits the
AD210 to be applied as an input or output isolator, in single or
multichannel applications. The AD210 will maintain its high
performance under sustained common-mode stress.
Providing high accuracy and complete galvanic isolation, the
AD210 interrupts ground loops and leakage paths, and rejects
common-mode voltage and noise that may other vise degrade
measurement accuracy. In addition, the AD210 provides protection
from fault conditions that may cause damage to other
sections of a measurement system.
