AD8610/AD8620,pdf datasheet (O
消耗积分:5 | 格式:rar | 大小:386 | 2009-08-28
duke刘
分享资料个
The AD8610/AD8620 are very high precision JFET input ampli-
fiers featuring ultralow offset voltage and drift, very low input
voltage and current noise, very low input bias current, and wide bandwidth. Unlike many JFET amplifiers, the AD8610/AD8620
input bias current is low over the entire operating temperature
range. The AD8610/AD8620 are stable with capacitive loads of over 1000 pF in noninverting unity gain; much larger capacitive
loads can be driven easily at higher noise gains. The AD8610/
AD8620 swing to within 1.2 V of the supplies even with a 1 kΩ
load, maximizing dynamic range even with limited supply volt-
ages. Outputs slew at 50 V/μs in either inverting or noninverting gain configurations, and settle to 0.01% accuracy in less than
600 ns. Combined with high input impedance, great precision,
and very high output drive, the AD8610/AD8620 are ideal
amplifiers for driving high performance ADC inputs and
buffering DAC converter outputs.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
