Using Op Amps as Comparators
消耗积分:2 | 格式:rar | 大小:433 | 2009-09-02
李丽
分享资料个
A comparator is a device with two input terminals, inverting and noninverting, and an output that usually swings from rail to rail. So is an op amp.
A comparator has low offset, high gain, and high common-mode rejection. So does an op amp.
So what is the difference? A comparator has a logic output that indicates which of the two inputs is at a higher potential. If its output is TTL or CMOS compatible (and many comparators are), it is always intended to be at one rail or the other—or making a rapid transition between the two.
评论(0)
发评论
下载排行榜
