AD8506/AD8508,pdf datasheet (D
消耗积分:5 | 格式:rar | 大小:620 | 2009-09-02
张强
分享资料个
The charge pump has been carefully designed so that switching noise components at any frequency, both within and beyond the amplifier bandwidth, are much lower than the thermal noise floor. Therefore, the spurious-free dynamic range (SFDR) is limited only by the input signal and the thermal or flicker noise. There is no intermodulation between input signal and switching noise.
Figure 45 displays a typical front-end section of an operational amplifier with an on-chip charge pump.
评论(0)
发评论
下载排行榜
