A common problem in motor drive systems when switching an inductive load are negative voltage spikes on the source nodes of the power stage. These spikes can be large in magnitude, which can cause damage to connected IC devices. This application report will look at the result of a bench test which stresses the DRV3205-Q1 with negative voltage transients on each of the gate and source pins.
