The MAX16835 current regulator operates from a 6.5V to 40V input voltage range and delivers up to a total of 350mA to one or more strings of high-brightness LEDs (HB LEDs). The output current of the MAX16835 is adjusted by using an external current-sense resistor in series with the LEDs. An enable input allows wide- range “pulsed” dimming. Wave-shaping circuitry reduces EMI. The differential current-sense input increases noise immunity. The MAX16835 is well suited for applications requiring high-voltage input and is able to withstand automotive load-dump events up to 40V. An on-board pass element minimizes external compo- nents while providing ±3.5% output current accuracy. Additional features include a 5V regulated output and short-circuit and thermal protection. The MAX16835 is available in a thermally enhanced, 5mm x 5mm, 16-pin TQFN package and is specified over the automotive -40°C to +125°C temperature range. Applications Automotive Interior: Map, Courtesy, and Cluster Lighting Automotive Exterior: Tail Lights and CHMSL Warning Lights for Emergency Vehicles Navigation and Marine Indicators General Illumination Signage, Gasoline Canopies, Beacons
