AD9878,pdf datasheet (Broadban
消耗积分:3 | 格式:rar | 大小:620 | 2009-09-08
tr12345
分享资料个
The AD9878 is a single-supply, cable modem/set-top box,
mixed-signal front end. The device contains a transmit path
interpolation filter, a complete quadrature digital upconverter,
and a transmit DAC. The receive path contains dual 12-bit
ADCs and a 10-bit ADC. All internally required clocks and an
output system clock are generated by the phase-locked loop
(PLL) from a single crystal oscillator or clock input.
评论(0)
发评论
下载排行榜
