AD7863,pdf datasheet (Simultan
消耗积分:2 | 格式:rar | 大小:630 | 2009-09-09
分享资料个
The AD7863 is a high speed, low power, dual 14-bit analog-to-digital converter that operates from a single 5 V supply.
FUNCTIONAL BLOCK DIAGRAM DGNDDB0BUSYCSCONVSTAD78632kΩAGNDAGNDVDDVREFDB13A0TRACK/HOLDTRACK/HOLDMUX2.5VREFERENCEOUTPUTLATCHRDCONVERSIONCONTROL LOGICSIGNALSCALINGSIGNALSCALINGSIGNALSCALINGMUX14-BITADC14-BITADCCLOCKVA2VB2VA1VB1SIGNALSCALING06411-001
Figure 1.
The part contains two 5.2 μs successive approximation ADCs, two track/hold amplifiers, an internal 2.5 V reference and a high speed parallel interface. Four analog inputs are grouped into two channels (A and B) selected by the A0 input. Each channel has two inputs (VA1 and VA2 or VB1 and VB2) that can be sampled and converted simultaneously, thus preserving the relative phase information of the signals on both analog inputs. The part accepts an analog input range of ±10 V (AD7863-10), ±2.5 V (AD7863-3), and 0 V to 2.5 V (AD7863-2). Overvoltage protection on the analog inputs for the part allows the input voltage to go to ±17 V, ±7 V, or +7 V respectively, without causing damage.
评论(0)
发评论
下载排行榜
