ADV7180,pdf datasheet (SDTV Vi
消耗积分:2 | 格式:rar | 大小:580 | 2009-09-11
分享资料个
The ADV7180 automatically detects and converts standard analog baseband television signals compatible with worldwide NTSC, PAL, and SECAM standards into 4:2:2 component video data compatible with the 8-bit ITU-R BT.656 interface standard.
The simple digital output interface connects gluelessly to a wide range of MPEG encoders, codecs, mobile video processors, and Analog Devices, Inc., digital video encoders, such as the ADV7179. External HS, VS, and FIELD signals provide timing references for LCD controllers and other video ASICs, if required.
更多视频解码器芯片:http://www.elecfans.com/soft/special/shipinjiemaqi/
评论(0)
发评论
下载排行榜
