AD7303,pdf datasheet (Voltage
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-17
路过秋天
分享资料个
The AD7303 is a dual, 8-bit voltage out DAC that operates
from a single +2.7 V to +5.5 V supply. Its on-chip precision output
buffers allow the DAC outputs to swing rail to rail. This device
uses a versatile 3-wire serial interface that operates at clock
rates up to 30 MHz, and is compatible with QSPI, SPI, microwire
and digital signal processor interface standards. The serial input
register is sixteen bits wide; 8 bits act as data bits for the DACs,
and the remaining eight bits make up a control register.
评论(0)
发评论
下载排行榜
