AD5220,pdf datasheet (Digital
消耗积分:2 | 格式:rar | 大小:514 | 2009-09-22
张敏
分享资料个
The AD5220 provides a single channel, 128-position digitally
controlled variable resistor (VR) device. This device performs
the same electronic adjustment function as a potentiometer or
variable resistor. These products were optimized for instrument
and test equipment push-button applications. A choice between
bandwidth or power dissipation are available as a result of the
wide selection of end-to-end terminal resistance values.
评论(0)
发评论
下载排行榜
