ADM2484E ,pdf datasheet (Isola
消耗积分:5 | 格式:rar | 大小:551 | 2009-09-25
分享资料个
The ADM2484E is an isolated data transceiver with ±15 kV
ESD protection suitable for high speed, half- or full-duplex communication on multipoint transmission lines. For half-
duplex operation, the transmitter outputs and receiver inputs
share the same transmission line. Transmitter Output Pin Y links externally to Receiver Input Pin A, and Transmitter Output Pin Z links externally to Receiver Input Pin B. Designed for balanced transmission lines, the ADM2484E
complies with ANSI TIA/EIA RS-485-A-1998 and ISO 8482:
1987(E). The device employs Analog Devices, Inc., iCoupler®
评论(0)
发评论
下载排行榜
