LM5034,pdf datasheet (High Vol
消耗积分:5 | 格式:rar | 大小:555 | 2009-09-29
张燕
分享资料个
The LM5034 dual current mode PWM controller contains all
the features needed to control either two independent
forward/active clamp dc/dc converters or a single high current
converter comprised of two interleaved power stages.
The two controller channels operate 180° out of phase
thereby reducing input ripple current. The LM5034 includes a
startup regulator that operates over a wide input range up to
100V and compound (bipolar + CMOS) gate drivers that
provide a robust 2.5A peak sink current. The adjustable
dead-time of the active clamp gate drivers and adjustable
maximum PWM duty cycle reduce stress on the primary side
MOSFET switches. Additional features include programmable
line under-voltage lockout, cycle-by-cycle current
limit, hiccup mode fault operation with adjustable restart
delay, PWM slope compensation, soft-start, and a 2 MHz
capable oscillator with synchronization capability.
评论(0)
发评论
下载排行榜
