LP3992,pdf datasheet (Micropow
消耗积分:3 | 格式:rar | 大小:550 | 2009-10-05
无人岛
分享资料个
The LP3992 regulator is designed to meet the requirements
of portable, battery-powered systems providing an accurate
output voltage, low noise, and low quiescent current. Battery
life will be prolonged by the ability of the LP3992 to provide
a 1.5V output from the low input voltage of 1.9V. Additionally,
when switched to a shutdown mode via a logic signal at the
shutdown pin, the power consumption is reduced to virtually
zero. The LP3992 also features short-circuit and thermalshutdown
protection.
评论(0)
发评论
下载排行榜
