LPC662,pdf datasheet (Low Powe
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-08
分享资料个
The LPC662 CMOS Dual operational amplifier is ideal for
operation from a single supply. It features a wide range of
operating voltage from +5V to +15V, rail-to-rail output swing
in addition to an input common-mode range that includes
ground. Performance limitations that have plagued CMOS
amplifiers in the past are not a problem with this design.
Input VOS, drift, and broadband noise as well as voltage gain
(into 100 kW and 5 kW) are all equal to or better than widely
accepted bipolar equivalents, while the power supply
requirement is typically less than 0.5 mW.
评论(0)
发评论
下载排行榜
