LMH2180,pdf datasheet (75 MHz
消耗积分:3 | 格式:rar | 大小:550 | 2009-10-08
分享资料个
The LMH2180 is a high speed dual clock buffer designed for
portable communications and applications requiring multiple
accurate multi-clock systems. The LMH2180 integrates two
75 MHz low noise buffers with independent shutdown pins
into a small package. The LMH2180 ensures superb system
operation between the baseband and the oscillator signal
path by eliminating crosstalk between the multiple clock signals.
评论(0)
发评论
下载排行榜
