LME49810,pdf datasheet (200V A
消耗积分:10 | 格式:rar | 大小:551 | 2009-10-08
杨福林
分享资料个
The LME49810 is a high fidelity audio power amplifier driver
designed for demanding consumer and pro-audio applications.
Amplifier output power may be scaled by changing the
supply voltage and number of power transistors. The
LME49810’s minimum output current is 50mA. When using a
discrete output stage the LME49810 is capable of delivering
in excess of 300 watts into a single-ended 8Ω load.
Unique to the LME49810 is an internal Baker Clamp. This
clamp insures that the amplifier output does not saturate
when over driven. The resultant “soft clipping” of high level
audio signals suppresses undesirable audio artifacts generated
when conventional solid state amplifiers are driven hard
into clipping.
评论(0)
发评论
下载排行榜
