ADC0816/ADC0817,pdf datasheet
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-12
h1654155275.3132
分享资料个
The ADC0816, ADC0817 data acquisition component is a
monolithic CMOS device with an 8-bit analog-to-digital converter,
16-channel multiplexer and microprocessor compatible
control logic. The 8-bit A/D converter uses successive
approximation as the conversion technique. The converter
features a high impedance chopper stabilized comparator, a
256R voltage divider with analog switch tree and a successive
approximation register. The 16-channel multiplexer can directly
access any one of 16-single-ended analog signals, and
provides the logic for additional channel expansion. Signal
conditioning of any analog input signal is eased by direct access
to the multiplexer output, and to the input of the 8-bit A/
D converter.
评论(0)
发评论
下载排行榜
