DS22EV5110,pdf datasheet (DVI,
消耗积分:5 | 格式:rar | 大小:565 | 2009-10-12
48674
分享资料个
The DS22EV5110 is a 6.75 Gbps (3 x 2.25 Gbps) extended
reach equalizer optimized for DVI™and HDMI™ cable extension
applications with a high performance re-clocking feature.
It supports 3 Transition Minimized Differential Signaling
(TMDS®) data channels and a single clock channel over
DVI™ v1.0, and HDMI™ v1.3a data rates up to 2.25 Gbps for
each data channel. The device incorporates a configurable
receive equalizer, a clock and data recovery (CDR) circuit and
a de-emphasis driver on each data channel over DVI v1.0,
and HDMI v1.3a data rates up to 2.25 Gbps for each data
channel. The device incorporates a configurable receive
equalizer with a clock and data recovery (CDR) circuit on each
data channel. The clock channel feeds a high-perfromance
phase locked loop (PLL) that regenerates a low jitter output
clock for data recovery, enabling the extended reach of driving
capability feature for repeater application.
评论(0)
发评论
下载排行榜
