MAX32600微控制器基于行业标准ARM® Cortex®-M3 32位RISC CPU,工作在高达24MHz。器件包括256KB闪存、32KB SRAM、2KB指令缓存,以及集成的高性能模拟外设。
MAX32600采用以下封装:192焊球、12mm x 12mm CTBGA;120焊球、7mm x 7mm CTBGA;108焊球、5.4mm x 4.3mm WLP。
除Maxim提供的免费工具之外,MAX32600也支持IAR的Embedded Workbench。IAR Embedded Workbench®将编译器、汇编器、链接器和调试器集成在一个IDE中,简单易用,提供高级和高效率优化功能,与硬件、RTOS产品以及中间件高度集成。IAR Embedded Workbench for ARM有多个版本,包括专门针对ARM Cortex-M核心家族设计的产品工具包。
LIFE SUPPORT POLICY MAXIM’S PRODUCTS ARE NOT DESIGNED, INTENDED OR AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT, LIFE SUSTAINING, DEVICES OR SYSTEMS OR APPLICATIONS, INCLUDING BUT NOT LIMITED TO, NUCLEAR, TRANSPORTATION OPERATING SYSTEMS, IN WHICH THE FAILURE OF SUCH GOODS COULD REASONABLY BE EXPECTED TO RESULT IN PERSONAL INJURY, LOSS OF LIFE OR SEVERE PROPERTY OR ENV− IRONMENTAL DAMAGE WITHOUT THE EXPRESS PRIOR WRITTEN APPROVAL OF THE PRESIDENT AND GENERAL COUNSEL OF MAXIM INTEGRATED PRODUCTS, INC. As used herein Life support, life sustaining devices or systems are devices which (a) are intended for surgical implant into the body, or (b) support or sustain life and whose failure to perform when properly used in accordance with instructions for use provided in the labeling can be reasonably expected to result in a significant injury to the user. A critical component is any component in a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system or to affect its safety or effectiveness. Document Disclaimer ©2016 by Maxim Integrated Products, Inc. All rights reserved. Information in this publication concerning the devices, applications, or technology described is intended to suggest possible uses and may be superseded. MAXIM INTEGRATED PRODUCTS, INC. DOES NOT ASSUME LIABILITY FOR OR PROVIDE A REPRES− ENTATION OF ACCURACY OF THE INFORMATION, DEVICES, OR TECHNOLOGY DESCRIBED IN THIS DOCUMENT. MAXIM ALSO DOES NOT ASSUME LIABILITY FOR INTELLECTUAL PROPERTY INFRINGEMENT RELATED IN ANY MANNER TO USE OF INFORMATION, DEVICES, OR TECHNOLOGY DESC− RIBED HEREIN OR OTHERWISE. The information contained within this document has been verified according to the general principles of electrical and mechanical engineering or registered trademarks of Maxim Integrated Products, Inc. All other product or service names are the property of their respective owners
