This revision obsoletes the previous revision of this Application Note, and covers additional material. This Application Note shows a simple component pre-distortion method that works for many popular Sallen-Key (also called KRC or VCVS [voltage-controlled, voltage-source]) filter sections. This method compensates for voltage-feedback and current-feedback op amps. Several examples illustrate this method. KRC active filter sections use an op amp and two resistors to set a non-inverting gain of K. resistors and capacitors placed around this amplifier provide the desired transfer function. The op amp’s finite bandwidth causes K to be a function of frequency. For this reason, KRC filters typically operate at frequencies well below the op amp’s bandwidth (f 《《 f3dB)。 ’Pre-distortion’ compensates for the op amp’s finite bandwidth by modifying the nominal resistor and capacitor values. The pre-distortion method in the Application Note compensates for the op amp’s group delay which is approximately constant when f《《 f3dB. One possible design sequence for KRC filters is: 1. Design the filter assuming an ideal op amp (K is assumed constant over frequency) • Select components for low sensitivities • Do a worst case analysis • Do a temperature analysis 1. Pre-distort the resistors and capacitors to compensate for the op amp’s group delay 2. Compensate for parasitic elements
