LMH0302,pdf datasheet (3Gbps H
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-14
申根换
分享资料个
The LMH0302 3Gbps HD/SD SDI Cable Driver is designed
for use in SMPTE 424M, SMPTE 292M, SMPTE 344M, and
SMPTE 259M serial digital video applications. The LMH0302
drives 75Ω transmission lines (Belden 1694A, Belden 8281,
or equivalent) at data rates up to 2.97 Gbps.
The LMH0302 provides two selectable slew rates for SMPTE
259M and SMPTE 424M / 292M compliance. The output driver
may be powered down via the output driver enable pin.
The LMH0302 is powered from a single 3.3V supply. Power
consumption is typically 125 mW in SD mode and 165 mW in
HD mode. The LMH0302 is available in a 16-pin LLP package.
评论(0)
发评论
下载排行榜
