This document explains how the MAX11300PMB1 featuring the MAX11300 20-port programmable mixed-signal I/O device interfaces with the Munich (USB2PMB1#) adapter board and how to use the GUI. The MAX11300PMB1 peripheral module provides the necessary hardware to interface the MAX11300 20-port device to any system that utilizes Pmod™-compatible expansion ports configurable for SPI communication (Figure 1)。 MAX11300 configuration software is a design tool used to create the configuration bit stream that is downloaded to the MAX11300 through the Munich adapter board (Figure 2)。 Refer to the MAX11300 IC data sheet for detailed information regarding operation of the IC and to the USB2PMB1 adapter board data sheet for detailed information regarding the Munich board and GUI. Refer to the MAX11300/MAX11301 PIXI™ Configuration Software User Guide for detailed information using the design tool.
