UM10204 pdf datasheet
消耗积分:5 | 格式:rar | 大小:555 | 2008-07-14
听风说梦
分享资料个
I2C, I2C-bus, Standard-mode, Fast-mode, Fast-mode Plus, Fm+, High Speed,
Hs, inter-IC, SDA, SCL
Philips Semiconductors (now NXP Semiconductors) developed a simple
bidirectional 2-wire bus for efficient inter-IC control. This bus is called the
Inter-IC or I
2C-bus. Only two bus lines are required: a serial data line (SDA)
and a serial clock line (SCL). Serial, 8-bit oriented, bidirectional data transfers
can be made at up to 100 kbit/s in the Standard-mode, up to 400 kbit/s in the
Fast-mode, up to 1 Mbit/s in the Fast-mode Plus (Fm+), or up to 3.4 Mbit/s in
the High-speed mode.
评论(0)
发评论
下载排行榜
