tl494英文资料下载
消耗积分:1 | 格式:pdf | 大小:1348KB | 2017-04-02
h1654155963.0963
分享资料个
    3 Description The TL494 device incorporates all the functions 1• Complete PWM Power-Control Circuitry required in the construction of a pulse-width- • Uncommitted Outputs for 200-mA Sink or modulation (PWM) control circuit on a single chip. Source Current Designed primarily for power-supply control, this • Output Control Selects Single-Ended or device offers the flexibility to tailor the power-supply Push-Pull Operation control circuitry to a specific application. • Internal Circuitry Prohibits Double Pulse at The TL494 device contains two error amplifiers, an Either Output on-chip adjustable oscillator, a dead-time control • Variable Dead Time Provides Control Over (DTC) comparator, a pulse-steering control flip-flop, a Total Range 5-V, 5%-precision regulator, and output-control circuits. • Internal Regulator Provides a Stable 5-V Reference Supply With 5% Tolerance The error amplifiers exhibit a common-mode voltage range from –0.3 V to VCC – 2 V. The dead-time • Circuit Architecture Allows Easy Synchronization control comparator has a fixed offset that provides approximately 5% dead time. The on-chip oscillator 2 Applications can be bypassed by terminating RT to the reference • Desktop PCs output and providing a sawtooth input to CT, or it can drive the common circuits in synchronous multiple-rail • Microwave Ovens power supplies. • Power Supplies: AC/DC, Isolated, With PFC, 》 90 W The uncommitted output transistors provide either common-emitter or emitter-follower output capability. • Server PSUs The TL494 device provides for push-pull or single- • Solar Micro-Inverters ended output operation, which can be selected • Washing Machines: Low-End and High-End through the output-control function. The architecture of this device prohibits the possibility of either output • E-Bikes being pulsed twice during push-pull operation. • Power Supplies: AC/DC, Isolated, No PFC, 《 90 W The TL494C device is characterized for operation from 0°C to 70°C. The TL494I device is characterized • Power: Telecom/Server AC/DC Supplies: for operation from –40°C to 85°C. Dual Controller: Analog • Smoke Detectors Device Information(1) • Solar Power Inverters PART NUMBER
评论(0)
发评论
下载排行榜
