bstract: This reference design enables a complete solution for powering Xilinx® Virtex®-6 FPGA GTX transceivers and Spartan®-6 FPGA GTP transceivers using Maxim‘s power-supply solutions.
This fully tested reference design provides a complete solution for powering Xilinx Virtex-6 field-programmable gate array (FPGA) GTX transceivers (on the Xilinx ML623 board) and Spartan-6 FPGA GTP transceivers (on the Xilinx SP623 board) using Maxim’s power-supply solutions. The GTX and GTP transceivers require two distinct power-supply rails each as follows:
Design Description—Virtex-6 FPGA GTX Transceiver
Power RailInput Voltage (V)Output Voltage (V)Current (A)Maxim Solution
MGTAVCC121.02510MAX8686
MGTAVTT121.26MAX8686
Design Description—Spartan-6 FPGA GTP Transceiver
MGTAVCC121.210MAX8686
These reference designs provide the required two power rails using four MAX8686 monolithic synchronous step-down converters. The GTX and GTP transceiver power-supply block diagrams are shown in Figure 1 and Figure 2.
