LM60,datasheet,pdf(2.7V, SOT-2
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-20
刘艳
分享资料个
The LM60 is a precision integrated-circuit temperature sensor
that can sense a −40°C to +125°C temperature range
while operating from a single +2.7V supply. The LM60’s
output voltage is linearly proportional to Celsius (Centigrade)
temperature (+6.25 mV/°C) and has a DC offset of +424 mV.
The offset allows reading negative temperatures without the
need for a negative supply. The nominal output voltage of the
LM60 ranges from +174 mV to +1205 mV for a −40°C to
+125°C temperature range. The LM60 is calibrated to provide
accuracies of ±2.0°C at room temperature and ±3°C
over the full −25°C to +125°C temperature range.
评论(0)
发评论
下载排行榜
