LM77,datasheet,pdf(9-Bit + Sig
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-22
分享资料个
The LM77 is a digital temperature sensor and thermal window
comparator with an I2C™ Serial Bus interface. The
window-comparator architecture of the LM77 eases the design
of temperature control systems conforming to the ACPI
(Advanced Configuration and Power Interface) specification
for personal computers. The open-drain Interrupt (INT) output
becomes active whenever temperature goes outside a
programmable window, while a separate Critical Temperature
Alarm (T_CRIT_A) output becomes active when the
temperature exceeds a programmable critical limit. The INT
output can operate in either a comparator or event mode,
while the T_CRIT_A output operates in comparator mode
only.
评论(0)
发评论
下载排行榜
